IPTV not supported channel format
Dear reader,
I'm new on the form.
I downloaded ProgDVB + ProgTV x32.
I loaded my IPTV m3u playlist.
The TV channels working great, I have a problem with playing the movies the program gives a error "not supported channel format"
I hope you can help.
Thanks in advance.
Regards,
Hans
Re: IPTV not supported channel format
HKe wrote:
Tue Oct 17, 2017 5:06 pm
Yes, it's mkv.
So I can look at movies in IPTV playlist
Thanks,
Hans
Hans the problem with prog dvb is they trying to achieve to many functions for Prog DVB ? they should work only on one prog just for Android IPTV M3U,and forget TV, and other functions, that's why Perfect Player does only IPTV m3U.and does it 100%
