Error Progdvb - EngineStrings_Render_FailedToCreate
thiagomespb
thiagomespb
Sat Jun 02, 2018 10:45 pm
#1 by thiagomespb
I installed the program .. it is with this msg .. attached
Windows 10
  • Sat Jun 02, 2018 10:50 pm
Re: Error Progdvb - EngineStrings_Render_FailedToCreate
What video card you have?
You can fix that if select other video renderer in ProgDVB. Options->Video->Codecs->Video renderer. For example evt
  • Sun Jun 03, 2018 7:38 am
thiagomespb
thiagomespb
#3 by thiagomespb
Gerforce 8400GS
  • Sun Jun 03, 2018 1:23 pm
Вы мне логи крашей присылали?
  • It is currently Fri Jun 26, 2026 3:31 pm
