Re: Testing
I finally downloaded the ProgTV app from that App Store into an iPad mini 3. I loaded 2 different types working playlists 1 using Xtream Codes the other using IPTV Client.. Both loaded the channels quickly Xtreme Codes loaded channel logos very quickly.
As I tried to view different channels in each I was not able to get any of them to play.
With the IPTV Client list every channel I tried said "Not supported channel format".
The list using Xtreme Codes all channels tried say Error! Timeout.
I didn't download "testflight" would it work if I did?
The links for both work with ProgTV BETA using android box and they work on MacBook Air using VLC Player.
