Hi,
Just installed the latest version of the shareware version in both computers (using win7 x32 and Win10 x64) and have the same problem with both versions.
I have a list of IPTV channels and using the scheduler I program to record 2 tv shows. The first show starts recording OK and everything goes OK. The problem is when the second show is triggered the first TV show doesn't finish the recording. I tested with recordings of 5 minutes of length and this is not happening. This happens when show is more than 5 minutes.
I attached a screenshot about the problem. The main problem is when a TV show is actually in recording mode and other TV shows starts to record, first one is blocked.
The recording setup is using the option "recording in background" but I tested in other modes and the problem is the same.
Attached screenshot with the problem.
http://www.imagebam.com/image/66853d1286108624
Re: IPTV scheduler doesn't finish recording with multiple recording sessions
#2Do you have logs for this picture?
#3Steps that I did:
1) Activated the log system in the application
2) Start the same scenario that I described in the last post
3) Pack log folder in a rar (including PNG capture of the situation)
Download link:
https://mega.nz/#!m9owhQrS!bmzEoeTF_SP6 ... RYwPEtFZRQ
If you want me to do more testing I will more than happy to do that
Thanks!
Download link:
Thanks!
