All channels say Error: Answer of server not recognized
User avatar
Toonces
Wed Sep 25, 2019 4:54 pm
#1 by Toonces
Trying out version 7.29.02. Added my m3u file, channel list appears, all channels give the above error and no video. Same m3u and channels show fine in an app called MyIPTV. On Windows 10 x64.
I have turned on logging and it generated numerous files.
  • Wed Sep 25, 2019 5:02 pm
Re: All channels say Error: Answer of server not recognized
Please send me 2-3 links of channels on my email. Or Logs.
  • Wed Sep 25, 2019 5:10 pm
kjac85
kjac85
Fri Sep 27, 2019 2:36 am
#3 by kjac85
I am having the same problem. M3u link works fine with VLC etc... but in progdvb it just gives me this error for every channel. I'll try and send you the log files if i can.
  • Fri Sep 27, 2019 2:41 am
#4 by Prog
Attaches not working in PM in this forum. You can send me on email. Also please update ProgDVB before that.
  • Fri Sep 27, 2019 6:03 am
#5 by Prog
Try last version of ProgDVB. Channels from log must working.
  • Fri Sep 27, 2019 1:25 pm
joaopunk
joaopunk
Wed Oct 02, 2019 9:49 am
#6 by joaopunk
Hi, I'm having the exact same problem. With other players the channels are fine, with progtv for android (any device) it says error!Answer of server not recognized.
Did you got any conclusions of what may be happening ?
  • Wed Oct 02, 2019 9:53 am
#7 by Prog
Please send me link of channel for test
  • Wed Oct 02, 2019 9:59 am
joaopunk
joaopunk
#8 by joaopunk
Done...
  • Wed Oct 02, 2019 10:29 am
Return to “IPTV”
Re: Two Bugs in v3 portable
I am not can repeat that. Please try last version of ProgTV. Still same?
Prog, Fri Sep 11, 2026 7:30 am
Thanks for report. I am retest that in near time.
Prog, Thu Sep 03, 2026 7:39 am
Hi there. I thought the portable had sorted out a bug I found in the windows app version, but sadly not. It seems that i
fredphoesh, Wed Sep 02, 2026 8:18 pm
Re: ProgTV3 portable
edit
fredphoesh, Wed Sep 02, 2026 7:46 pm
  • It is currently Sun Sep 13, 2026 12:36 am
