storage access problem on nvidia shield
#1been using progtv android beta for long time. recently it seems program cannot access storage, although it is enabled in settings. program crashes under every player except if engine is set to exoplayer. in settings under timeshift it wont navigate to storage directories, it gives me only /data/user0/... or /Android/data/progdvb directories only, not the usual directories in emulate storage. consequently players open with brief message about failure to create buffer and program exits. same problem when creating new souce, it can't navigate to .txt files in my storage area. this all was fine until very recently. i believe it is something do with the shield itself, i was wondering if anyone had any solution. i am unable to use record feature or any thing having to do with accessing normal storage. seems like a permissions issue. any help appreciated
