How I can change name of xtream codes playlist???
Thanks...
Re: Xtream Codes : Playlist name
#2In TV sourecs but not possible in modern version. I fix that in near weeks.
#4I have other question:
For Xtream Codes playlist, in VOD Series, how I see the seasons from series???
#5I am not remeber:) Very long time not test series. No serials in list?
#6For example, my Xtream Codes playlist has in VOD Series, The Good Doctor, that it has 3 seasons, but I'dont see them.
Do you understand me???
PD: My english is not good.
Thanks...
Thanks...
#7ivanimatrix wrote: ↑Wed Jan 08, 2020 6:42 pmFor example, my Xtream Codes playlist has in VOD Series, The Good Doctor, that it has 3 seasons, but I'dont see them.
Thanks...
Do you have the list on "Full Screen" or is it running down the left side of the screen? If you set it on Full Screen you should see which season the episodes are from.
#8btw. What provider name and contact email? I need test account for debug.
#9Now I am working with series and need help with testing. Do you have Windows PC?
ps: Can you give test login?
