Diseqc Module
#16
Hi Juergen
More to understand.
I did as you say. Set up LNB parameters but How can I coordinate the transponder list with each satellite if I do not see any western satellite on the sat pull down list .As I had mentioned on my previous tread that on the pull down menu I don’t see any satellites located over western hemisphere.
The list start at 0030 Telecom 2A all the way to 1130 Koreasat 2, Palapa C2 and them following the 3355 Intelsat 603 to 3590 Thor 2/3 Intelsat 10-02 .
Maybe the module is not being update will all the sats??
#17
WHERE don't you see the american birds, in ProgDVB DiSEqC / LNB settings or on a dialogue of the plugin?
Regarding ProgDVB, it reads from the Transponders sub folder, which should include tons of suitable INI files. The display names of the lists are read from inside of the files. You should coordinate all of those to the LNB(s) in DiSEqC / LNB settings. Multiple positions per LNB supported, just add...
Regarding scanning, you should find each entry from the menue, to enable scanning of each position seperately.
Plugin itself?
No idea, as I'm not using a motor here.
So I simply did not test it.
Diseqc module
#18
Back to you Juergen
and thanks again for the help.
Definitely I don’t see the Americans birds on diseqc dialog.
On Progdvb settings Diseqc dialog all the sat are there.
So it means that the same satellites list that PRogdvb have on root directory should be the same that shows the plugin dialog?
It is not my case.
#19
Once again, I don't use any motor nor that plugin, so I don't know about it's behaviour or in case bugs.
No idea, where it looks for transponder data (and bird system names), and what style it wants them to be like.
But you've got two strong weapons, curiosity and your editor...
If it would really want west style names, well, perhaps make suitable copies, starting on one of your choice...
Also possible, you're suffering from bad settings for east / west limits, somehow.
Else, no idea, someone else had to help you...
#20
To recieve DVB-S it is necessary to have a "special" DiSEqC-instruction (for changing channels). The antenna-system (Single Cable Distribution (SCD)) is in accordance with EN 50494. TechniSat supports only DiSEqC 1.0 by this card. With this module is it possible to get tv working? The guy from TechniSat-hotline says, with this card it would´nt working.
TechniSat Skystar 2 DVB-S-Card
