Hello everyone i have a very annoying issue , so far will all and every version of progdvb i have tried .
i ll try to explain the problem :
I have a Technisat Skystar Usb 2 Hd (sat)
Technisat CableStar Combo HD CI USB (dvbt)
WinFast DTV Dongle Gold BDA Device (dvbt)
Terratec T/C Stick (dvbt)
Terratec S7 usb ( sat )
i usually use only the first 2
Now the odd problem is ..................if i use them together sat doest work anymore
it says there is signal and everything ........but the screen is totally back
if i disconnect ( from usb port ) one of the 2 , the other keeps back to work normally .
Things i know for sure :
Usb ports work and work fine
recievers work and work fine
drivers work and work fine
why i know ? cos any other prog i have used work without issues with them both connected and i can switch from sat to dvbt or vice versa without any problem.
The only thing that i m left with is........its a prg dvb bug been there from centuries and never fixed , and its quite annoying to have to disconnect everytime a reciver to wtach the other
another thing , if for example i use another dvbt reciever (even disalbling from the prog the 2 thecnisat cards ) nada it doesnt work ..............the only solution is always to disconnect one phisically from usb
simply put if the 2 technisat cards are connected at the same time , prodvb will never work !
all other programs works seamsly
Re: very very annoing issue
#4yes x32 on every windows version ( 64 bits ) same issue
tried 7 , 8.1 and 10
no matter what the 2 recievers won't go fine together
#7On my MSI MS-7641 ver: 3.11 motherboard on Windows 10 pro x64 two 4 gb slats, this console started without problems
Here are links to videos on YouTube there at the end in the second or third I'll show you what Windows 10 pro started on this motherboard:
Part 1 https://www.youtube.com/watch?v=zIWJH_u6a6Y
Part 2 https://www.youtube.com/watch?v=RUW0LLvZBPY
Part 3 https://www.youtube.com/watch?v=oNEJjKtxeHU
