Hi, is there an option to move between channels in the following way:
Press "arrow up", the next channel name and info details will appear but only after pressing "enter" it will switch to the channel
Thanks for your helps
Re: Control: moving from channel to next channel
#3I Don't want to open the list. I just want the option to press "Arrow UP" or "Arrow down" and see the name of the next or previous channel and the relevant info (same as pressing enter)
If I want to me to it, I would like to press "Enter" and the it will switch to it
Example:
I watch channel kookoo1.
I press "up"
Now I see the EPG Info of channel kookoo2 .
I press "Enter"
now the channel changes from kookoo1 to kookoo2
if I press the "UP" more than once, it will display kookoo3 ….4....5 etc
If I press the "down" it will move from kookoo5....4.....3
Example:
I press "up"
I press "Enter"
#4Quite exotic. I think you got used some not good player. What player?
