Hi .. I've used for 3-4 years xtream-editor for edit my lists.. No problems in Progdvb ( Android and PC ) . I've now new editor ( iptveditor.com ) . I can see al logos but there's no epg in players.. I've tested in Progdbv android Normal and Beta. ProgDvb For PC and ProgTv for Pc. Same problem...
There is only 1 or 2 epgs visibles.. in 100 channels fior example but all epg are assigned and other playes charge epg normally...
I've writed here but problem is present also in android. Thanks in advance
Re: Epg Problem with Iptveditor
#2Do you have some m3u list? Please send me m3u before and after editor
#5WINDOWS - Tested Progdvb for Windows Prerelease 40.4b 64 bit, now epg works. Also on ProgTV for Windows,
ANDROID - ProgTV 2.68.2 Epg not works - ProgTV 3.08.4 Beta Epg Works
UWP - ProgTVb 1.2.2.0 Epg not works
P.S. After installing prerelase or Progdvb epg not working. i've totally cleaned relations in guide and imported another time and begin working epg. I've tried to clean another time and upgraded to 7.40.5 and seem working. In download zone ProgTV 2.6823 and .4 i nos liked to any download in you website ( Also Playst Store not upgrade ProgTV Standard )
Sorry for PM.........
#6Hi... with new versions on Progdb and Prog Tv, standars and beta seems work everywhere now ( Windows Pc , Android and UWP ) . Only in 1 case i've removed Relations in guide and after works.. Thanks for support
