Hi, I'm using ProgDVB Standard Edition on Windows 10 21H1 and Hauppauge WinTV-soloHD https://hauppauge.co.uk/site/products/data_solohd.html
I tried but I can't use the remote control.
Can anyone help me set it up or tell me if it's not possible?
Thanks
Re: Configure Remote Control
#3It's the remote control included with the TV Tunner, and it works fine with the WinTV v10 from Hauppauge, but ProgDvb is much better.
I send you some images of the Remote Control in case it helps you identify it, I don't know any other specification.
