stream quality
Hi is there any way to change the stream quality in progtv for android. The 5 main channels i watch are all SD quality except for two of them, they play in Low quality. It is not a provider issue has all 5 channels play in SD quality in two other apps i have used. Is there any where in the settings to change the two channels to SD quality. Thanks. Roger.
