in ProgDVB or ProgTV when i configure the Sat->IP Source, i'll enter the IP of the Fritzbox and then i can choose from the predefined dvb-c frequencies, but no matter what i choose it doesn't find anything, i'm also not really sure if its even trying to get to the fritzbox, as normally i would see dvb-c receivers on the fritzbox using it in ah tuner display menu...
i tried ProgTV mainly but also ProgDVB doesnt make ah difference, using ProgTV i'll see an "error" for split seconds when different frequencies are switched for scanning...
i would exactly now my frequencies form the provider furthermore i'm not sure if ProgDVB/TV even uses the correct settings?! didn't found ah list whats behind the predefined settings
any help appreciated
best regards
Stephan
