Hi,
All channels started today throwing a popup "Access Authentication" asking for login and password. The url to the .ts is fine and works on other apps
Re: Access Authentication popup
#2That mean server not give access. Try change user agent in TV Sources->IPTV client
#3Changed and now it works. Thanks
Can I ask for this please. My m3u changes every 15 minutes. Can you amend the "Update interval" from minimum of 1 hour to minutes? Also, when the list updates it does not auto-sort in the same order and adds new groups to the bottom of the list. I then have to manually re-sort it. Can you make it auto-sort based on last sort choice when source list updates?
Thank you!!
Thank you!!
#5Yes I can use those to sort ok but after the m3u refreshes it puts new groups at the bottom and does not automatically sort the list using my last sort order. Can you make it auto-sort every time it refreshes the tv source m3u? And also make the refresh interval in minutes rather than 1 hour minimum.
#6I am thinking about best implementation. I am not like add complex control for enter hours and minutes.
btw, what provider you use? Fast changes of links is not good. For example impossible restore channel after lost of connection.
