We have zoom level, but I've noticed I mostly use it to zoom out ads on sides on some video channels,
so it would be nice to have a Crop video feature instead exactly for that - e.g. crop 50 pixels from bottom of the screen (or any other side) in the setting or via a gesture (e.g. zoom out on video sides, not in the center for general zoom)
Re: Feature request: - Crop video
#2Where do you want the center of new zoom?
ps: Тут есть русский раздел в форуме.
#4Not clear.
ps: Current zoom bad or not working on this device? Some device not support picture more size then screen. You can try same in ffmpeg mode.
#7ffmpeg has crop?
ffmpeg has ~3 fps only, so can't try it anyway
#12Do You want a black frame around the picture in place part of picture? Why?
#13To remove video-ads from there. or Information panels
And Video can be fit into the screen (4:3 or 16:9) after the cropping I hope
#15It is. but it works differently. See this image: Red zone - after zoom
Blue zone - after crop & fit
