Prog DVB will not find any audiostream in a movie I try to watch with audioformat E-AC3. I use LAV Audio decoder that supports E-AC3 but ther seems that Prog DVB isn't able to find the audiostream but Video is OK.
From another player I manage to see the stream-details, see attached jpg-file.
Re: No sound
#3No option in Service menu to record ( i's a IPTV-stream) but I asked my friend to record a 5 min TS-file with his player.
In Prog DVB 7.45.07 is an option to download sample but that seems to be a complete file in DAT-format (>1 GB) and I'm not able to open it in Prog DVB.
I tried to attach the TS-file my friend recorded but it's too big (169 MB), what to do ?
Re: No sound
#5I have such a problem too, though I doubt if it's ProgDVB problem, not a channel's one. I have recorded a file.
https://disk.yandex.ru/d/5bH-BZHA8JICwg
TeVii S-460
Re: No sound
#6TeVii S-460
Re: No sound
#7Interesting fact is that switching to another channel and after that again reopening the problem one helps sometimes to restore the sound, but if you just click on the problem channel trying to reopen it - doing this does not help to restore the sound.
TeVii S-460
Re: No sound
#8Well I have been mistaken: clicking on the problem channel sometimes works too.
TeVii S-460
Re: No sound
#9And sometimes it happens that one movie on the channel goes without sound, it ends and another movie starts to go - already with sound. Unfortunately, I can't write it down right now.
TeVii S-460
Re: No sound
#10For one of the channels, audio is not detected at all, it is broadcast without sound. Maybe this channel does not have an audio at all, or maybe there is an audio, but ProgDVB does not see it.
https://disk.yandex.ru/i/4sInf-cfGus57A
TeVii S-460
Re: No sound
#11По русски наверное можно?
Попробовал последний пример, он и в плеере без звука. В ProgDVB функций записи писали? Нужно TSRecoder-ом или подобной утилитой для записи без изменений
Re: No sound
#12Да, последний пример - это пример того, что иногда канал может транслироваться без звука. Такое тоже бывает. Но помимо этого бывают ситуации, когда канал, имеющий аудионесущую открывается без звука. Первые два примера в ПрогДВБ были во время записи без звука, в плеере же звук есть. Иногда после кликания на проблемный канал звук появляется, а иногда нет. А иногда бывает так, что один фильм на канале идёт со звуком, а другой без звука, а третий опять со звуком.
Да, я TS-Recorder'ом записывал.
TeVii S-460
Re: No sound
#13As I enabled TS recorder on that stream I first received errormessaget about audiostream being E-AC3 and then the prog crashed. Normally I get a chans to alter codecs after a crash but this time Prog DVB closes down immediately every time I restart. I guess I have to uninstall and make a fresh new install.
Re: No sound
#14Да, и я в TS-Recorder'е установил точечку напротив "All transport stream" - она там по умолчанию, вроде, не стояла, чтобы были записаны все потоки.
TeVii S-460
