version before was stable.
Now i get between 2 an 10 minutes freezing screen and in the down left  the text "traffic is chipered" .
Switsching to another channel fixes the problem for severel minutes.
Pkease fix ist.
																																							Re: 7.46.09 x64
#6Founded. Not good. Some problem in ProgDemux. You can use MS Demux
ps: Is this a frequent problem? It is possible record sample of TS with this problem?
Re: 7.46.09 x64
#7It is not consstantly. Saturday and Sunday it works fine, but yesterday it startet with a crash after 40 minutes aof viewing without automatic restart and than after 10 to 4 minutesthe error traffic chippered  occurs.
							Re: 7.46.09 x64
#9Today the first 2 hours are working, but than "traffic is cippered" regardless of demux. i used progdemox ms-demux elcard demux and tv-demux. all the same after 2 to 4 minutes the errot.
							Re: 7.46.09 x64
#10"traffic is chipered" mean some TS flags have "crypted" marker. Do you use softcam?
							Re: 7.46.09 x64
#12Yesterday all works fine with tvdemux except 1 crash aber 1 1/2 hpurs of viewing.
Dont know how i get tvdemx and where it is located, but ist works better than progdemux, MD demux, elcard demux. ni errors so far.
							Re: 7.46.09 x64
#13I downloaded and installed ProgDVB 7.47.0 last night but now I notice that it is removed from download.
Should I go back to 7.46.09 ?
 Please send me zip on email
