Signal quality
Hey Prog,
Recently they changed the cable tv to fiber and now some of the programs don't have 100% signal quality. The problem is that on my TV I can see the channels perfectly, but with ProgDVB the channels have artefacts, sound issues or they show no signal. How can this be fixed? It seems if the signal quality is unde 80%, progdvb can't show the channel.
Re: Signal quality
Sat Mar 04, 2023 10:59 am
This is hardware level. ProgDVB only show levels value in interface. You must change DVB tuner or improve cables.
ps: Check connections at first.
Connections are good. I suspect the problem is with the fiber to catv converter. I will try to find a better quality converter than the one that they installed and see if it helps.
