Prog wrote: ↑Sun Jun 09, 2024 5:39 am
This message mean you enable some DVB device but not setup it. Please disable it in TV Sources or setup.
i uninstalled latest version and reinstalled a few times used auto and it loads playlist and channels but but wont open channels get black screen, I only use prog DVB for iptv with xc codes or m3u , are these the correct codecs ;see pic attach;? is there old versions of the prog that i can try. My PC is an old intel 5 Lenovo 70 series Think center use to work ok a few month ago just by doing the auto install but now nothing works.
