0xc0000005 and 0xc0000374 errors with the latest version of the ProgDVB with IPTV
Hello,
I am using the latest version of professional. I also tried 7.65.2 and 1, also the prerelease version. Tried updating and changing the versions of the GPU driver. The program crashes after I start 3 or more recordings on iptv, randomly but pretty soon after the last recording. Logs are attached.
Here is the error on event viewer;
Log Name: Application
Source: Application Error
Date: 2025-02-28 18:08:46
Event ID: 1000
Task Category: Application Crash Event
Level: Error
Keywords:
User: ADMINIS-84LL7S2\hasan
Computer: ADMINIS-84LL7S2
Description:
Faulting application name: ProgDvbNet.exe, version: 7.65.1.0, timestamp: 0x67aecc4a
Faulting module name: ntdll.dll, version: 10.0.22621.4974, timestamp: 0x36d7bcf8
Exception code: 0xc0000374
Error offset 0x000000000010cba9
Faulting process id: 0x0xB04
Application start time: 0x0x1DB89F23F7CFADD
Faulting application path: C:\Program Files\ProgDVB x64 Professional\ProgDvbNet.exe
Faulting module path: C:\windows\SYSTEM32\ntdll.dll
Report id: f7c9a9d1-199d-4187-aeff-3426f284c2a4
Faulting package full name:
Application id associated with the faulting package:
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Application Error" Guid="{a0e9b465-b939-57d7-b27d-95d8e925ff57}" />
 <EventID>1000</EventID>
 <Version>0</Version>
 <Level>2</Level>
 <Task>100</Task>
 <Opcode>0</Opcode>
 <Keywords>0x80000000000000000</Keywords>
 <TimeCreated SystemTime="2025-02-28T15:08:46.7713717Z" />
 <EventRecordID>5863</EventRecordID>
 <Correlation />
 <Execution ProcessID="11156" ThreadID="7976" />
 <Channel>Application</Channel>
 <Computer>ADMINIS-84LL7S2</Computer>
 <Security UserID="S-1-5-21-794922054-463556279-2007011979-1003" />
 </System>
 <EventData>
 <Data Name="AppName">ProgDvbNet.exe</Data>
 <Data Name="AppVersion">7.65.1.0</Data>
 <Data Name="AppTimeStamp">67aecc4a</Data>
 <Data Name="ModuleName">ntdll.dll</Data>
 <Data Name="ModuleVersion">10.0.22621.4974</Data>
 <Data Name="ModuleTimeStamp">36d7bcf8</Data>
 <Data Name="ExceptionCode">c0000374</Data>
 <Data Name="FaultingOffset">000000000010cba9</Data>
 <Data Name="ProcessId">0xb04</Data>
 <Data Name="ProcessCreationTime">0x1db89f23f7cfadd</Data>
 <Data Name="AppPath">C:\Program Files\ProgDVB x64 Professional\ProgDvbNet.exe</Data>
 <Data Name="ModulePath">C:\windows\SYSTEM32\ntdll.dll</Data>
 <Data Name="IntegratorReportId">f7c9a9d1-199d-4187-aeff-3426f284c2a4</Data>
 <Data Name="PackageFullName">
 </data>
 <Data Name="PackageRelativeAppId">
 </data>
 </EventData>
</Event>
Does anyone have any idea to solve this? Thanks in advance!
Logs.zip
(147.73 KiB) Downloaded 933 times
Re: 0xc0000005 and 0xc0000374 errors with the latest version of the ProgDVB with IPTV
Hi,
I have a problem that seems relatively similar except I have the error immediately on startup, so I can't launch the application.
Everything works fine until version ProgDVB7.65.4Pro, problems appeared in version ProgDVB7.65.6Pro and is still present in latest version ProgDVB7.66.0Pro.
I'm also using IPTV.
Here is the log from event viewer (2 entries):
Nom de l'application défaillante : ProgDvbNet.exe, version : 7.65.6.0, horodatage : 0x67cbfaac
Nom du module défaillant : unknown, version : 0.0.0.0, horodatage : 0x00000000
Exception code: 0xc0000005
Fault offset: 0xa253ae72
Identifiant du processus défaillant : 0x985C
Heure de début de l'application défaillante : 0x1DBA6EFB114F7A9
Chemin de l'application défaillante : C:\Program Files (x86)\ProgDVB Professional\ProgDvbNet.exe
Chemin du module défaillant : unknown
ID du rapport : d65b1a0a-eedb-4b0a-9857-ffa5a8af80f6
Nom complet du package défaillant :
Package défaillant – ID d'application relatif :
Détecteur d'erreurs 1758925407253441979, type 5
Nom d’événement : BEX
Réponse : Non disponible
ID de CAB : 0
Signature du problème :
P1 : ProgDvbNet.exe
P2 : 7.65.6.0
P3 : 67cbfaac
P4 : StackHash_2beb
P5 : 0.0.0.0
P6 : 00000000
P7 : PCH_F6_FROM_ntdll+0x00079A8C
P8 : c0000005
P9 : 00000008
P10 :
Fichiers joints :
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.16dbeb18-3f6f-47ce-88c8-cccec78c15c2.tmp.dmp
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.b2d5d069-98c0-4bee-ad0d-85d7fa53d758.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.42da7e34-bdea-484d-98f2-9c4e7c921f0a.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.d430095d-27ea-405c-903c-381a806db5b9.tmp.txt
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.b09b3290-ff99-402f-8b9f-2670c9176d63.tmp.xml
Ces fichiers sont peut-être disponibles ici :
\\?\C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_ProgDvbNet.exe_a4f559595ece36a864ad4576f8bed1ee0c5934f_84f64ad4_68b9089c-63d4-4909-94fa-ea4a550681ea
Symbole d’analyse :
Nouvelle recherche de la solution : 0
ID de rapport : d65b1a0a-eedb-4b0a-9857-ffa5a8af80f6
Statut du rapport : 268435456
Récipient avec hachage : 773a160682a04e7b2868f556b5c02dbb
GUID CAB :0
This is really annoying because I cannot update after the working version 7.65.4
#15
btw, do you have message box when ProgDVB crash? Any more information in this dialog? I am very need stack of crash.
no message box at all, program just closes itself after 3 or 4 seconds.
Do use some addition settings in ProgDVB->TV sources? I am still not can repeat crash
I only have one source which is "DVB Over IP". This source points to a local M3u playlist containing all channels, with the following format:
#EXTM3U
#EXTINF:-1 ,ECHOUROUK TV SD
udp://@232.0.1.229:8200
#EXTINF:-1 ,ATV EUROPE
udp://@232.0.2.235:8200
#EXTINF:-1 ,BEST OF SHOPPING
udp://@232.0.2.237:8200
