Re: 0xc0000005 and 0xc0000374 errors with the latest version of the ProgDVB with IPTV
#20
quack wrote: ↑
Mon Apr 07, 2025 8:03 pm
I removed the DVB Over IP sources
Then with the new version, I added the M3U list source
I can see the channels but as soon as I click on one channel, the program crashes and closes itself
I can guarantee the bug is due to changes between releases 7.65.4 and 7.65.6 (for some reason the 7.65.5 cannot be downloaded so I can't try)
Yes, this is the question what change was made after 7.65.4 to cause this issue?
#28
kaya wrote: ↑
Sun Apr 13, 2025 10:04 am
There is no crash in free versions. I solved the problem by formatting Windows. Only computer drivers and necessary codecs are installed. I think the error may be caused by Windows update or antivirus blocking. This is not certain, the computer's OEM drivers should be used. I am trying to learn the cause of the error in updates and installations.
The issue is caused by ProgDVB engine, I have now switched to LibVLC and i no longer have an issue.
