by Fikret Turedi
Good day. In Prog Dvb x64 version, in Transponder folder, the "satellites.xml" file that I downloaded from the link you gave in "readme.txt" (http://satellites-xml.org) does not work. It does not see the list of Transponders with xml extension at all. Is there an example "satellites.xml" file that you are sure works in ProgDVB? It is okay even if it is not up to date for me. Because I can update it. As long as there is a working "satellites.xml" file in ProgDVB. Good luck. Thank you in advance for your interest.
