No longer able to load playlists
Hi,
I've used ProgDVB for a number of years without issue.
In the past few weeks i've been unable to load or connect to any of my 3 playlists.
My ISP is V......M.... and the usually block certain ones at peak times (Saturdays) which didn't really bother me. If I wanted to use it on a Saturday, running through a VPN would bring it all back.
My problem is that none of my 3 accounts will load or connect. This only happens with ProgDVB as I also use other apps and PC software which all work fine.
Any suggestions would be really appreciated as ProgDVB is the only one with a record function.
Here's the error I get now with or without the VPN.
Thank you
