UHD picture no longer showing, only sound
masheee
masheee
Mon Mar 28, 2022 9:42 pm
#1 by masheee
When using IPTV, If i use ProgDVB engine i get no picture with any UHD channels, if i change to LibVLC it again works, has something changed with Engine to break this?
  • Sat Aug 22, 2026 12:37 pm
Re: UHD picture no longer showing, only sound
  • Sat Aug 22, 2026 12:55 pm
masheee
masheee
#3 by masheee
I tried changing video renderer and tried all codecs, the only thing that fixed it was changing engine, 3070Ti
  • Sat Aug 22, 2026 1:00 pm
masheee
masheee
#4 by masheee
  • Mon Aug 24, 2026 6:16 pm
#5 by Prog
  • Mon Aug 24, 2026 8:07 pm
masheee
masheee
#6 by masheee
Thank you, I will wait, cannot find pre release of Network edition.
  • Tue Aug 25, 2026 4:39 pm
#7 by Prog
Please wait 1-3 days for next release.
  • Tue Aug 25, 2026 5:02 pm
Re: проблемма со звуком
Попытка поправить работу с eac3 в пререлизе
Prog, Sat Oct 17, 2026 6:44 pm
Re: Вывод звука wasapi и asio
Снава столкнулся с глюками asio. Поправил в пререлизе.
Thanks! I check that.
Prog, Sat Oct 17, 2026 7:17 am
Thanks for report. This bug already fixed. Please wait ProgTV3 update. Hi! thanks for hear us. I try the two new up
AndresMaxx, Fri Oct 16, 2026 2:25 pm
  • It is currently Tue Oct 20, 2026 4:40 am
