Two Bugs in v3 portable
Hi there.
I thought the portable had sorted out a bug I found in the windows app version, but sadly not.
It seems that if you are watching tv, then choose either scheduler or Guide, the video image gets smaller and the right and bottom of the screen is very thick black bars... see the video I uploaded.
https://videoblurb.com/mp/guide+schedul ... kimage.mp4
The second bug is where the ProgTV window does not remember it's size or position and loads up MUCH bigger than the monitor it is meant to be on. This was the problem I had with the windows app version of ProgTV too.
It may have something to do with the fact that the top monitor on my setup is at 125% scale, the other monitors at 100%.
Your v2 of this app does not have any problem at all remembering where it needs to be and what size... only from v3 (both versions) there is this problem.
See video https://videoblurb.com/mp/notremembersizeposition.mp4
Thanks,
Mark.
