I have downloaded File Graber 1.21, and copyed all the files from the zip file to the ProgDVB\modules\ directory.
When I start it, it starts saving a lot of .dat files in the output directory. I can then open the .dat files with a text viewer to view the file types, and then rename them manually to the right file types.
But isn't there a way to get File Graber to save the files with the right extensions, istead of saving them all as .dat?
Also when I press the Filter button in File Graber to enter the filter options, the list with file types is empty. Can this be fixed?
By the way; is there a english version of FileGraber.readme available?
