Hi,
Changing channel to another on different satellite doesnt more work (with SS1 soft mode under XP)
To change satellite, only the scan transponder have real effect, method : select needed channel, in scan transponder function select (working) TP on the goal satellite, lock 2 time or more, exit and voila the dish is set correctly. Seem not really pratic when old 4.85 work perfect for USALS (also some 5.xx, not equal to 11)
5.11.8 pro still crash under XP at startup when SS1 is enabled.
For adding LNB, only editing manually diseqtree.ini can enable it.
I cant get my TT 3200 S2 working correctly with ProgDVB (no problem with DVBviewer)
