hi ..
i have installed ProgDVB4.85.3 since 8 months with BroadLogic card
when i try install the new version ProgDVB4.87.9 i faced problem that when i change frome channel to another there is different delay to view th channel and some times i must click more than once to view the channel ..
i re install the previous version and no any problems ..
There is no must to deinstall previous versions to test a new one. Just install the new one into another folder.
Regarding the switch delay difference, this may result from buffer settings, codec versions, stations and transmission details, and many more details
Keep in mind, you're using a pretty complex software structure instead of real hardware, for audio, video, stream filtering and more.
thanks for reply ..
but i compared the settings in two version and i make it same .. and the problem still there ..
when i open the progdvb the first and second channel i choose it .. it work with no delay .. but when i choose more the delay occure ... and my be i wait for 12 sec to view the channel
satellite is Nilesat 101,102 ..
and as i tell you in progdvb ver 4.85.3 there is no problem .. but with ProgDVB4.87.9 the delay was occured ...
i get back and install the previous version and i will use it untill fix the problem in the new version ...
thanks for all
thanks for all
