No Captions - problem
I have quite a problem that I cannot solve.
This seems to happen only on 28.2 deg east satellite. A large number of channels appear without a caption, where the caption should be it will read 'noname SID=(number) TID=(number)' where the number relates to the sid/tid for each channel.
These channels are named and will appear fine on Mytheatre etc.
this problem only seems to exist on 28.2 east and updating the captions doesn't even help. I have a very strong signal from this sat.
Using progdvb vers 4.22
Any ideas or help would be much appreciated as I cannot solve it.
thanks Gary
Try ProgDVB version 4.75 or slightly above, or even a modern one.
4.22 had severe issues with channel names on european birds, as far as I know, due to some hot fixes for the Americans then.
However, to give the scanner a bit more time, add this to your ProgDVB.ini at the end:
[Scaner]
AfterChangeTransponderDelay=3000
ProgDVB 4.75 and 4.84.1 (w9x) are scanning fine here, even 28.2E, whereat the Britain beam transponders come in quite weak over here, on my 1m dish with central LNB pointing to 19.2E...
Just a few stations will still have no name and / or provider captures, as there aren't any transmitted.
Just put vers 5.11.09 on and it has resolved the caption issue.
Unfortunately the audio starts to break-up after about 5 mins and after 10mins the audio totally stops and the picture stutters very badly. Is there something obvious I'm doing wrong.
Usin XP-Pro AMD XP-6000 dual core 2gb ram, 7950 graphics card.
This may (but not must) be related with timeshift settings.
Try to install without, or limit size to far below half of your free physical RAM, or put the timeshift buffer onto another physical HDD (not just partition).
thanks Jurgen but unfortunately that does not work.
The audio breaks up after about 2 mins and the picture shortly afterwards.
I'm trying a few other settings to see if I can resolve it.
Juergen, I will post this onto a new thread as the topic has changed. I have had these kind of problems with mytheater as have others and it appears to be due to the dual-core CPU, I hope this is not the case with progdvb.
Gary
