I installed ProgDVB 5.12.3, when I open it, it gives an error message:
"The application failed to initialize properly (0xc0000135). Click on OK to terminate the application"
I have nothing in the /plugin folder. I just reinstalled Windows and I wanted to try out ProgDVB 5.
No, it wasn't installed. I though it cam with xp. After I installed the framework, it worked but I still had a problem with the codecs. I've downloaded a few codecs and now everything works perfectly!
I have no problems with it. I like the new skins, especially the windows media player type.
Thanks Prog for making such a great software.
