Hey!
I have a problem with the plugins, I installed Progdvb (XP SP2) and it used to work, but i restored then system and now it´s not working. The program doesn´t read the Plugins. The folder is the same i used to use before (it worked very well). I reinstalled the program several times and even though, it doesn´t want to work
HELP
Necessary location of a plugin also depends on itself.
Most plugins come with a readme, to explain.
Folder names will surely be critical.
Some plugins have extra files, perhaps with extra requirements for their location or path entries in some .ini files.
This gets really important, if the path for ProgDVB (or a special outside folder) was changed.
Plugins must reside in ProgDVB base folder or 'Plugins' subfolder there, to be detected at ProgDVB launch..
However, we don't discuss 3rd party plugins over here.
Check dvbn.happysat.org for more on plugins.
Generally, most popular plugins are working fine in ProgDVB.
