Record with progdvb, freezes, Dolby Digital
I do have some difficulty with Progdvb 5.11.9.
First, when i record a movie, I can only record one. When I start to record a second time, the progdvb freezes after about 30 min. My solution so far is, record one movie, terminate progdvb and start the program again.
Only watching sat channels are most of the time ok, only a few time the program freezes too.
I can not record the Audiopart in Dolby. At the moment I usig a trial copy on my laptop. This laptop has no 5.1 audiocard, is this maybe the reason why not?
I think at least the program should record in dolby, regardles of the Audiocard. I also have Cyber Link Power DVD on this Computer and tried AC3 codexes. Hier is the next question, does I need to order mpeg codex with Progdvd, or can I use the codex which I already have with the DVD program..
Later on I using an Twonky Server on an AMS150 NAS and stream the movie to an Zyzel AMD1000. Both units suporting dolby, including an Yamaha RX 2700.
My last question is, I also tried Progdvd on my Desktop, but it was very unstable and not realy useable. Now the 21 Days are expired and I can not try the record function anymore on this on. I have an explanation why maybe this computer are so unstable with Progdvb. It's an old AMD K7 CPU 2100 Mhz and with 512MB memory. The Satreceiver is an Technisat USB 2 plus. The original Technisat software does nut run at all,on the desktop, the progdvb are at least a bit, but unstable. Does anyone know if this problems are because of performance.
Thanks for any comands. sorry for my english, it was better years ago
update of previus post
I foregot to say both operating systems are Win XP and the Memory on the AMD K7 unit is 1 MB. Last night I installed the free versin 5.12.9 on the AMD PC but very unstable with the error message shown below. I recorded a few minutes a movie, but record still only in Stereo, even with installed Souround sound card.
at ProgDvbNet.OSDChannelCaptionForm.timer1_Tick(Object sender, EventArgs e)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.832 (QFE.050727-8300)
ProgDvbNet
Assembly Version: 5.12.9.0
Win32 Version: 5.12.09
CodeBase: file:///C:/Programme/ProgDVB/ProgDvbNet.exe
EngineApiWrapper
Assembly Version: 1.1.0.2
Win32 Version:
CodeBase: file:///C:/Programme/ProgDVB/EngineApiWrapper.DLL
msvcm80
Assembly Version: 8.0.50727.163
Win32 Version: 8.00.50727.163
CodeBase: file:///C:/WINDOWS/WinSxS/x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.163_x-ww_681e29fb/msvcm80.dll
System
System.Drawing
ProgDvbNet.bc
Assembly Version: 1.0.1.0
Win32 Version: 1.0.1.0
CodeBase: file:///C:/Programme/ProgDVB/ProgDvbNet.bc.DLL
IPDev.Skins
Assembly Version: 1.2.7.0
Win32 Version: 1.2.7.0
CodeBase: file:///C:/Programme/ProgDVB/IPDev.Skins.DLL
ProgDvbNet.EPG
Assembly Version: 1.0.0.1
Win32 Version: 1.0.0.1
CodeBase: file:///C:/Programme/ProgDVB/ProgDvbNet.EPG.DLL
Accessibility
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
System.Design
enabled.
For example:
<configuration>
</configuration>
