Re: Feature Requests
#452Current Main System:
MOBO: Sabretooth FX990 R2.0
CPU: FX-8350BE@4,7Ghz
Cooling: NZXT x52
GPU: RX580 8GB
SSD: Samsung EVO 850 250GB
RAM: 16GB PC3-12800 Quad Channel
Monitor: MSI Optix G27C2
OS: Windows 10 x64 Pro
Cooling: NZXT x52
GPU: RX580 8GB
#454progdvb!?,Prog wrote: ↑Tue Jan 07, 2020 5:31 pmTry this https://www.progdvb.com/download_progdv ... lease.html
Diz ↑ version turned my licensed pro version invallid !? Result → no shedule recording possible !?
WTF!?
Cooling: NZXT x52
GPU: RX580 8GB
Cooling: NZXT x52
GPU: RX580 8GB
#456As ussuall → x64 network edition !
correction isnt this → ProgDVB x64 Professional from the link you created supposed to be the network edition ?
Cooling: NZXT x52
GPU: RX580 8GB
Cooling: NZXT x52
GPU: RX580 8GB
#457at this link → https://www.progdvb.com/download_progdvb.html !! I can find back the network edition by name but no rev.v7.31.4"E" !!!
Cooling: NZXT x52
GPU: RX580 8GB
Cooling: NZXT x52
GPU: RX580 8GB
#459Thanks you..
But ermm.. progdvb still adds records to ms sheduler but withouth the checkbox set to on for "wake computer for the task"!!
With as result no go !! Computer still wont wake up to execute the task... untill i check that box "wake computer to run task" under conditions !! Thats it ?
Have you tried it your self progdvb? Which os or linux are u ?
thanks for the effort anyway,
td
EDIt: Record Button in progdvb from the link is greyed out aswell
Cooling: NZXT x52
GPU: RX580 8GB
Cooling: NZXT x52
GPU: RX580 8GB
#463progdvb !! Wots up with the license / registration of dizz software ? AGain, the app is in trial mode !!!! This time iam sure i took "network edition" !!
Now, it doesnt record anything , not even when computer is awake !!!
EDIT: NO... again → "f" revision Network edition not listed in prelisted page !! just checked, although the shedules are now listed in ms sheduler with checkbox on ... But the license prevents any sheduled recording i guess !!
sighn!!
Cooling: NZXT x52
GPU: RX580 8GB
Cooling: NZXT x52
GPU: RX580 8GB
#465a. no registered version "F" !!
b. No sheduled recording because of it ... or not .. but no recording!
Something weird happening , and i couldnt rectify it ..; so i did an system restore , and now progdvg revision x.x.34 without e, f or abc does his thing as expected and wakes up from sleep for recording !
Ofcourse, i have to force it by editing the sheduled record in ms sheduler and enable the checkboxes i mentioned !
td,
Cooling: NZXT x52
GPU: RX580 8GB
Cooling: NZXT x52
GPU: RX580 8GB
