Fixing Device not started? Screen shots
Hi all, I would like to try and fix a Device not started problem I'm having with ProgDVB.
This is what I get when I try to start ProgDVB. If I click on OK the program loads but there is no satellite signal. I know the dish, LNB and SS2 is working fine as it works perfectly using DVBDream. If I go to the device within ProgDVB and disable then re-able it some times I can get a satellite signal.
Why is the scan button grayed out? If I select the lock button I get this.
I loose all quality. Any ideas on how to fix this?
More info that might help: Windows XP Pro, SP2, SS2 driver version 4.4.3. LNB Invacom QPH-031. LOF1 10750
Thanks, SB
Re: can not get device to work
Prog wrote:You select some not correct device in settings->device list
Hi, please advise what is the correct device. I have been working on this problem for days. Just can not get it to work.
Some times I get this message instead of the one above.
Note the grayed out enable box.
Windows device manager see it ok and it works in DVBDream.
Any ideas?
Thanks, SB
Got it working
Hi all, removed both ProgDVB and DVBViewer TE using windows control panel > and and remove programs then manually deleted the directories these programs where in then re-installed DVBViewer first (with the Technisat drivers v 4.4.3.0) then re-installed ProgDVB and now it works.
:D
Later, SB
