Channels with subtitles
I have ProgDVB6.02.01Pro.exe with 15 days left... I want purchase this software, but I encountered one bug, when i choose one channel with subtitles the software crashes in few seconds.
I don´t have the audio processor choosed...
Another channels (without subtitles) working fine...
How I do to fix this bug??
Prog wrote:What channel name?
Can you record more long sample 2-3 minutes?
Channel: PCM in Amazonas 61º W
I can´t capture anymore but the program crash...
One time the error box appears saying this :arrow: :arrow: :arrow: :arrow:
at (* , * , )
at ..( , diseqItem)
at ProgDvbNet.MainForm.( , )
at ..(TreeNode , )
at ..(Point , )
at ..(Object , MouseEventArgs )
at IPDev.Skins.MSTreeView.OnMouseClickEx(MouseEventArgs e)
at IPDev.Skins.MSTreeView.OnMouseUp(MouseEventArgs e)
at System.Windows.Forms.TreeView.WmNotify(Message& m)
at System.Windows.Forms.TreeView.WndProc(Message& m)
at IPDev.Skins.StyleTreeView.WndProc(Message& m)
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
CodeBase: file:///D:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
ProgDvbNet
Assembly Version: 6.2.1.0
Win32 Version: 6.02.01
CodeBase: file:///D:/Archivos%20de%20programa/ProgDVB/ProgDvbNet.exe
EngineApiWrapper
Assembly Version: 1.2.2.0
Win32 Version:
CodeBase: file:///D:/Archivos%20de%20programa/ProgDVB/EngineApiWrapper.DLL
msvcm80
Assembly Version: 8.0.50727.762
Win32 Version: 8.00.50727.762
CodeBase: file:///D:/WINDOWS/WinSxS/x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_6b128700/msvcm80.dll
CodeBase: file:///D:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///D:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///D:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
ProgDvbNet.bc
Assembly Version: 1.0.8.0
Win32 Version: 1.0.8.0
CodeBase: file:///D:/Archivos%20de%20programa/ProgDVB/ProgDvbNet.bc.DLL
IPDev.Skins
Assembly Version: 1.3.5.0
Win32 Version: 1.3.5.0
CodeBase: file:///D:/Archivos%20de%20programa/ProgDVB/IPDev.Skins.DLL
ProgDvbNet.EPG
Assembly Version: 1.0.3.0
Win32 Version: 1.0.3.0
CodeBase: file:///D:/Archivos%20de%20programa/ProgDVB/ProgDvbNet.EPG.DLL
ProgDvbNet.CC
CodeBase: file:///D:/Archivos%20de%20programa/ProgDVB/ProgDvbNet.CC.DLL
ProgDvbNet.Win
Assembly Version: 1.0.0.0
Win32 Version:
CodeBase: file:///D:/Archivos%20de%20programa/ProgDVB/ProgDvbNet.Win.DLL
ProgDvbNet.resources
Assembly Version: 0.0.0.0
Win32 Version: 0.0.0.0
CodeBase: file:///D:/Archivos%20de%20programa/ProgDVB/es-ES/ProgDvbNet.resources.DLL
Accessibility
CodeBase: file:///D:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Design
CodeBase: file:///D:/WINDOWS/assembly/GAC_MSIL/System.Design/2.0.0.0__b03f5f7f11d50a3a/System.Design.dll
System.Xml
CodeBase: file:///D:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Drawing.Design
CodeBase: file:///D:/WINDOWS/assembly/GAC_MSIL/System.Drawing.Design/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.Design.dll
System.Configuration
CodeBase: file:///D:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
enabled.
For example:
<configuration>
</configuration>
This file very important for me. You can start ProgDVB with /NoGraph key and disable EPG parser in settings->Options->other.
ProgDVB not can crash in this mode.
Prog wrote:This file very important for me. You can start ProgDVB with /NoGraph key and disable EPG parser in settings->Options->other.
I have already removed the EPG parser... When I start PrgDVB with /NoGraph appears this error and can´t start:
at ProgDvbNet.MainForm.(Object , EventArgs )
at ProgDvbNet.MainForm.()
at (UInt32 , UInt32 , Int32 )
at (* , * , )
at ..( , diseqItem)
at System.Windows.Forms.Form.OnShown(EventArgs e)
at IPDev.Skins.SkinForm.OnShown(EventArgs e)
at System.Windows.Forms.Form.CallShownEvent()
at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)
at System.Threading.ExecutionContext.runTryCode(Object userData)
at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbacks()
mscorlib
Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400)
CodeBase: file:///d:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
ProgDvbNet
EngineApiWrapper
Win32 Version:
msvcm80
Assembly Version: 8.0.50727.1433
Win32 Version: 8.00.50727.1433
CodeBase: file:///D:/WINDOWS/WinSxS/x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1433_x-ww_5cf844d2/msvcm80.dll
System
System.Drawing
ProgDvbNet.bc
IPDev.Skins
ProgDvbNet.EPG
ProgDvbNet.CC
System.Xml
ProgDvbNet.Win
Win32 Version:
Accessibility
System.Design
enabled.
For example:
<configuration>
</configuration>
Prog wrote:Thanks. This sample good for test. I am try fix it in next version.
I am happy to help you...
One question: If I buy your program now ... ¿Can I have this fix or upgrade?, Or I have to pay again
