Hi all,
Since a while, i'd post a major problem on the forum that my ProgDVB always crash on my Vista configuration. Prog was very pretty, and after we had a conversation in PM.
The fact : ProgDVD is always crashing on my Vista configuration even i'm MCP (Microsoft Certified Professionnel for Windows Vista) certified!!! and i
Response by Prog:
It works perfectly on my Vista clients witch represent 80% of my customers. So you are the fault (I don't see that someone else had a problem on the forum).
I'd just installed 6.04 and it is worst. Actually when ProgDVB crash, a shutdown of the system doesn't work (This is new!). Must do a cold reset by presssing my power button for 5 seconds.
When launching version 6.04, 3 times on 4 tries, it doesn't work.
So if there is some people who had a problem of crashes with ProgDVD (I'd paid for the pro version), please tell Mr Prog that there was a major problem of stability with his program.
Even waiting for him to correct our buyed application, just try a newbee program (SmardDVB 0.0.6 alpha, free to use) to watch your favorites TV programs without bugs or crashes like ProgDVB can't garantee for months (Seems to me that i was wrong on my choose).
I'm very angry about all of this. Prog is taking me as i was the only one who had problems of crashes with ProgDVB, i don't believe that there were no others customers with my same problem.
So my vote is for a ProgDVB 7.0 without major bugs even a new version which can at least be a bit launch.
I'm working with the majors decoders on my workstation and all (ALL) of them works ... perfectly. ProgDVB is the only (ONLY) one which is not stable.
I regret that i bought this program...because all of majors problems are still not resolved.
I'm patient, but there are limits!!!!!!!!
