Pctv sat ci - lbn problem
i have truoble of swithing between lbn's
have a diseq with 4 lbn connected to a dreambox(working perfect)
lbn out on the dreambox to my sat card in the computer..
i have managing to find some channels on each lbn (but far from all)...
and now i'm "stucked" on sirius 5,0E (every channel is working)
and when i swich to another lbn ... noting happens( % is where low)
is it my card or the program that cant switch between lbn's?
What can i do ??
Try out all four possible combinations of the "distinguish by" DiSEqC options.
Plus, find out, if the missing channels / transponders have anything in common, like f.e. all above the switch frequency or alike.
Don't know your card, but I can assure you, ProgDVB can handle DiSEqC LNB switching, as I'm using four LNBs and a 4/1 DiSEqC 1.0 (/ 2.0) for years now over here.
Just one known limitation, no DiSEqC with BDA drivers.
im just scanning all four lbn now in Mytheatre...
scanning channels is working... but then when i want to switch between lbns
it the problem
how do i know a have the "best driver" for my card...
its a pctv sat ci =twinhan visionplus sat ci its the same card(chip)
ok thanks now it seem to work.....
but on some channels , i have "lines" i the picture,if it's rapid movment then the lines comes....
i have default settings in sound/video option (mainconcept)
should a install codec packs and try other settings....
have a pctv sat ci and an ati radeon card....
Cyberlink,ffdshow,nVidia give a better picture quality ;)
Hi SiLencer
do u mean to make the graph in progDVB as u pointed ...
from where i can find ffdshow
regards
