CI Problem
Hi,
I have just started using the ProgDVB to watch FTA, am loving it.
I have also now added a CI, AverTV Sategate with IRDETO Cam, but cannot see it in ProgDVB, each time I try to access the CI, only get "Waiting for Data" and does not detect the CI.
I have made sure the CI is enabled.
I am using a AverTV DVB-S Trinity a707 card with the CI on Vista x86.
Is this CI supported?
Thanks in advance.
Avermedia site says that the DVB-S card is ProgDVB compliant, which is working ok with ProgDVB. The CI i have is a irdeto, and this does not showup, when i try to acces the CI CAM in progDVB. IT sits on "Waiting for Data".
barryq7 wrote:
Prog wrote:Azurewave clone?
How can i tell? I am new to DVB world, is there a way i can tell if it is Azurewave clone?
Can anybody tell me as to how to get the CI Cam working??
When i click on the CI option, it just sit there on "Waiting for data"
