i just installed the "ProgDVB6.43.2x64Pro" (not registered yet cause i want to test if it is working with my machines) and the "pms_small".
And actually it is not working
At first try I didn't install the media server in the same folder as the progdvb program it self (maybe it should search for an installed version or at least warn/ give the user an hint on that?!).
2. try:
Now when i try to start the "Prog Media server (lite interface)" its throwing out
(translated from german)
"program couldn't start correctly (0x000007b). press ok to close)
what do i have to do?
thx in advance
