no picture and sound #1 by bawde hi, i used version 6.50 for a long time and it workes fine. now i wanted to update progdvb, but with the new versions i get no tv picture an sound. i don't really know what the problem is. i use winXP 32bit. QuoteSun Sep 25, 2011 8:00 am
Re: no picture and sound #2 by Prog Try scan channels again. Do you have channels after scan? QuoteSun Sep 25, 2011 8:46 am
Re: no picture and sound #3 by Joe210 Same problem for me and curent version 6.72.2 x64 - no sound and no video. Before I used 6.61.3 x64 on Windows 7 64bit without any problems. I'm using the same driver (TV Sources say's "Hauppauge WinTV 88x DVB-S/S2 Tuner/Demod") as the topic starter. Card is a Hauppauge Nova-HD S2. "Channels Search" doesn't find any channels. Level is always at 100, quality always 0%. I added some log-files of ProgDVB - maybe it helps. Joe. Last edited by Joe210 on Wed Oct 05, 2011 4:33 pm, edited 1 time in total. Attachments Logs.zip Log files (14.05 KiB) Downloaded 377 times QuoteWed Oct 05, 2011 4:31 pm
Re: no picture and sound #4 by Prog Try change settings->Device options. Or install ProgDVB to empty directory. QuoteWed Oct 05, 2011 4:32 pm
