no problem here using skystar 2 rev. 2.3x,driver 4.40 and progdvb 4.81.1....
which progdvb version ? try other (newer/older)...
try other codecs....
try the ms patch...KB896626
i´ve already tryed that but no change
you tried this all ?
btw. you make another post with no details !!!
what do you tried...you can only get real help if you post details !!
tried progdvb versions ?
which dvbcard driver ? tried another one ?
which codecs do you tried ?
etc...
yes i installed all progdvb versions i found, then i tried nvidia,intervideo,cyberlink codex but also the same problem
the microsoft patch is already installed i´ve read this in another post....
i don´t know what to do now.... driver rev.4.4.0 progdvb 4.81.1 , skystar 2 rev. 2.3x too
switch off unneeded progdvb modules (subtitle etc..)...and other plugins...maybe this helps
running fine here...like 99% of other progdvb versions...
Sorry , then i can´t do more for you...
windows ist only installed for progdvb and mediaportal.no other progs! i dont understand it....
windows logs this error:
Ereignistyp: Fehler
Ereignisquelle: Application Error
Ereigniskategorie: Keine
Ereigniskennung: 1000
Datum: 20.01.2007
Zeit: 14:12:12
Beschreibung:
Fehlgeschlagene Anwendung progdvb.exe, Version 4.0.0.0, fehlgeschlagenes Modul quartz.dll, Version 6.5.2600.2749, Fehleradresse 0x000ae166.
but thx for your help :-)
mixmix99 wrote:windows ist only installed for progdvb and mediaportal.no other progs! i dont understand it....
Ereignistyp: Fehler
Datum: 20.01.2007
Zeit: 14:12:12
Beschreibung:
Do you have s2emu or vplug plugin?
if.....then read here : viewtopic.php?t=9
This forum is strictly legal !
OK
but don't use vplug in progdvb , it is unstable,
ffdshow filter video is unstable,
but ffshow filter audio is stable
recomended cyberlink and nvidia filter are stable
