Application crashes everytime i open Progdvb. Crashes again and again.Restarts again and again...
My CARD:Technisat Skystar 2.6D PCI
Re: Progdvb restarts continuously
#3i've had the same error some times
there were 3 different errors with me...
open %installdir%\ProgDVB.ini
search for LastChannelID
pe LastChannelID={28680,824633777546,0 dev 2,0,3635075002022849395}
and remove everything behind the =
LastChannelID=
save the ini and try to start
this error happens when you watched a channel, close progdvb, update your codecs (aspecially ac3) and start progdvb again
another option is a crashed vplug... just delete the vplug log...
or remove the value of your tv-card...
LastChannelID=
#4i could not solve the problem so i have installed a new windows.
