ProgDVB activated, ProgTV will not activated
Paderman
Paderman
Mon Dec 17, 2012 4:08 pm
#1 by Paderman
Hello,
I just now use my key, I could ProgDVB activate, but when I try to activate ProgTV, it say ProgTV is registered and must be restarted, and when I open ProgTV, it says, it's not activated.
Is ProgTV a own product?
Regards/Gruß
Paderman
  • Mon Dec 17, 2012 4:17 pm
Re: ProgDVB activated, ProgTV will not activated
Yes, you must buy upgrade license to "ProgDVB+ProgTV" for use both software.
  • Mon Dec 17, 2012 4:21 pm
Paderman
Paderman
#3 by Paderman
OK, thank you for this info :)
Regards/Gruß
Paderman
  • Mon Dec 17, 2012 5:10 pm
Вы мне логи крашей присылали?
  • It is currently Sat Jun 27, 2026 9:11 am
