Media server not remembering channels
    • ProgServer
    • ProgMusic
    • ProgFinder
    • Elecard ViCont
  • Privacy Policy
Acuario
Acuario
Thu Jan 31, 2013 2:06 pm
#1 by Acuario
Hi,
any update on the Media Server losing the selected channels on a restart of ProgDVB?
I have ProgDVB installed in c:\progdvb and it is really a problem having to reset the channels each time I restart it.
  • Sun Feb 24, 2013 7:14 pm
Re: Media server not remembering channels
Do you start ProgDVB or PMSLauncher? portable installation?
  • Mon Feb 25, 2013 4:54 am
Acuario
Acuario
#3 by Acuario
I start ProgDVB. It is set to have all settings saved for all users in the same directory (is that the portable one?)
  • Mon Feb 25, 2013 8:05 am
#4 by Prog
Check xxx\ProgDVB\Channels directory. is it channels here?
  • Mon Feb 25, 2013 12:00 pm
Acuario
Acuario
#5 by Acuario
In the Channels directory I have:
YouTubeLogos directory
Channels.dat
Channels.ini
CL-8ba..etc.
epg.dat
MostPopular.tree
XmlTvRelations.dat
  • Mon Feb 25, 2013 6:45 pm
#6 by Prog
Looks good... Still not have good idea about this bug. But thanks for information.
ps: Do you have same problem in free version of server?
  • Tue Feb 26, 2013 4:27 am
Acuario
Acuario
#7 by Acuario
The only version I've tried is the small version (which expires tomorrow!). I can try the free one but from what it says it doesn't work with VLC so is of little use to me.
  • Tue Feb 26, 2013 8:42 pm
#8 by Prog
Please mail me for trial key or use other version of server next 14 days.
  • Wed Feb 27, 2013 4:31 am
Return to “Modules”
Editing is still available. Where did you look for him and did not find him?
Prog, Fri Nov 06, 2026 7:55 am
I am fix bug in > 3.15 version. Please wait. Thanks! The new version 3.15.1 is already updating the channel list, b
AndresMaxx, Fri Nov 06, 2026 3:44 am
Re: Bug - Missing First Chara…
You can try prerelease of ProgDVB https://www.progdvb.com/download_progdvb_prerelease.html and enable "original name" in
Prog, Sun Nov 01, 2026 7:57 pm
Do you mean "US| DISCOVERY HD appears as S| DISCOVERY HD"=>DISCOVERY HD? ProgTV/ProgTV must create folder for "DISCOVERY
Prog, Sun Nov 01, 2026 6:04 am
  • It is currently Fri Nov 06, 2026 11:13 am
