Hi,
I'm using a Terratec Cinergy HT PCI MK2 under Windows 7 (64 bit),
which supposes to work in dvb-t and in analogue mode.
ProgDVB realizes the digital tuner of my card correctly,
but there's no analogue capture device
and therefore no possibility to search for analogue channels as well.
Does anyone know how to get it working?
Re: ProgDVB and analogue TV
#2Analog supporting very depended from device. I am remove this function (Analog) from modern versions.
ps: I am recommend using some old analog TV software for analog TV. It is very specific task
