Url into channells proprieties..
#46
Can't find any URL into channells proprieties...
6.25... on client and server...
now with windows 7 32 bit on client and server
no firewall..
no stream.. no audio no video..
I can take channell list on client... change channells from client and can see change and video and audio on server...
Prog media client setting: unicast, server 192.168.1.2, port 10999, transport stream, my user, my pass.
#48
Dear Sirs,
I have serious issues with Prog Media server software from the date I bought it which .
I have sent an email to Progdvb support team.
I am waiting for their response.
Regards,
Toofanian
fix..
#49
Don't work...
On another configuration:
Windows 7 32 server
windows 7 64 client
I can see transponder flow but no audio no video..
On client and server version 6.25.1
No firewalls..
If i see channell proprieties I can't see for example: AC3 (pid:1505) or English (page 778) in the rispective fields..
it seems problem is in the server. After a new installation of the server I can see video and audio on the client.
After I close and restart server no audio or video..
IT Seems to work also resetting setting on server..
Boh..
Re: fix..
#50
olgos762 wrote: I can see transponder flow but no audio no video..
No firewalls..
if run with /debug? Did you see any error message? What`s message in log?
Re: Progdvb server and client problem
#52
Hi
befor prog media server Ver.4 , VLC was working fine in any mode shoutcast (HTTP) mode or IPTV to play back the channels but now with new version VLC faild to playback the channels in any mode
as i received error message "your input can't be opened " and in VLC messages details (access_http error : failed to read answer)
while windows media player is working well.
#53
moody1976 wrote:Hi
I did many tests using prog dvb ver 6.95.1 or 6.95.2 with prog server home or prog media server and the result in http mode vlc not working , i did my tests on server itself with loop back (127.0.0.1) and still vlc not working (in IPTV mode vlc working fine now)
Note : to be accurate when i m used any interface in network setting the vlc worked in http mode once or twice randomly but when i changed the interface setting or close prog the vlc did not work again even when i am back to any network interface
Mr PROG any advice ?
#55
Prog wrote:Can you show me some vlc logs?
Thanks Mr. PROG
I'm trying to get logs from vlc but i coludn't so i m seraching how i can get log from vlc to show it to you
I d like to tell you more results about my tests :
1-all my tests that i did it before was on windows xp sp3 (server & client)
2-i did another test on windows 8 as a server in this case vlc worked fine when i try it on server itself or when i'm used another pc as a client with windows 8 vlc working fine in both modes (http / iptv)
3-when i'm used pc with windows xp sp3 as client with server windows 8 the vlc not worked in http mode
4-i discoverd some thing by the accident (in case windows xp as server & client)
I m try to playback a channel in server itself and before the vlc gave me the error
At same time i'm try to playback a channel on client (xp) (in this case the vlc worked in http mode ) !!!!!!!! (when i close the vlc on client and try to playback again it not worked it worked only if i try to run vlc on server itself at same time)
Thanks again
#56
Mr.Prog here the log of VLC
main debug: adding item `http://172.17.13.32:1234/ch/rotana.m3u' ( http://172.17.13.32:1234/ch/rotana.m3u )
main debug: rebuilding array of current - root Playlist
main debug: rebuild done - 1 items, index -1
main debug: processing request item: http://172.17.13.32:1234/ch/rotana.m3u, node: null, skip: 0
main debug: resyncing on http://172.17.13.32:1234/ch/rotana.m3u
main debug: http://172.17.13.32:1234/ch/rotana.m3u is at 0
main debug: starting playback of the new playlist item
main debug: meta ok for (null), need to fetch art
main debug: creating new input thread
main debug: Creating an input for 'http://172.17.13.32:1234/ch/rotana.m3u'
qt4 debug: Adding a new MRL to recent ones: http://172.17.13.32:1234/ch/rotana.m3u
main debug: looking for meta fetcher module: 1 candidate
lua debug: Trying Lua scripts in C:\Documents and Settings\Administrator\Application Data\vlc\lua\meta\fetcher
lua debug: Trying Lua scripts in C:\Program Files\VideoLAN\VLC\lua\meta\fetcher
qt4 debug: IM: Setting an input
main debug: using timeshift granularity of 50 MiB, in path 'C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp'
main debug: `http://172.17.13.32:1234/ch/rotana.m3u' gives access `http' demux `' path `172.17.13.32:1234/ch/rotana.m3u'
main debug: creating demux: access='http' demux='' location='172.17.13.32:1234/ch/rotana.m3u' file='\\172.17.13.32:1234\ch\rotana.m3u'
main debug: looking for access_demux module: 0 candidates
main debug: no access_demux module matched "http"
main debug: TIMER module_need() : 0.076 ms - Total 0.076 ms / 1 intvls (Avg 0.076 ms)
main debug: creating access 'http' location='172.17.13.32:1234/ch/rotana.m3u', path='\\172.17.13.32:1234\ch\rotana.m3u'
main debug: looking for access module: 2 candidates
lua debug: Trying Lua playlist script C:\Program Files\VideoLAN\VLC\lua\meta\fetcher\tvrage.luac
access_http debug: http: server='172.17.13.32' port=1234 file='/ch/rotana.m3u'
main debug: net: connecting to 172.17.13.32 port 1234
main debug: using meta fetcher module "lua"
main debug: TIMER module_need() : 2.428 ms - Total 2.428 ms / 1 intvls (Avg 2.428 ms)
main debug: removing module "lua"
main debug: searching art for http://172.17.13.32:1234/ch/rotana.m3u
main debug: looking for art finder module: 2 candidates
lua debug: Trying Lua scripts in C:\Documents and Settings\Administrator\Application Data\vlc\lua\meta\art
lua debug: Trying Lua scripts in C:\Program Files\VideoLAN\VLC\lua\meta\art
lua debug: Trying Lua playlist script C:\Program Files\VideoLAN\VLC\lua\meta\art\00_musicbrainz.luac
lua debug: Trying Lua playlist script C:\Program Files\VideoLAN\VLC\lua\meta\art\01_googleimage.luac
lua debug: Trying Lua playlist script C:\Program Files\VideoLAN\VLC\lua\meta\art\02_frenchtv.luac
lua debug: Trying Lua playlist script C:\Program Files\VideoLAN\VLC\lua\meta\art\03_lastfm.luac
main debug: no art finder module matching "any" could be loaded
main debug: TIMER module_need() : 5.080 ms - Total 5.080 ms / 1 intvls (Avg 5.080 ms)
main debug: art not found for http://172.17.13.32:1234/ch/rotana.m3u
main debug: connection succeeded (socket = 1380)
access_http error: failed to read answer
access_http debug: switching to HTTP version 1.0
main debug: connection succeeded (socket = 1388)
access_mms error: failed to read answer
main debug: no access module matching "http" could be loaded
main debug: TIMER module_need() : 441.771 ms - Total 441.771 ms / 1 intvls (Avg 441.771 ms)
main error: open of `http://172.17.13.32:1234/ch/rotana.m3u' failed
main debug: dead input
main debug: changing item without a request (current 0/1)
main debug: nothing to play
qt4 debug: IM: Deleting the input
main debug: TIMER input launching for 'http://172.17.13.32:1234/ch/rotana.m3u' : 471.369 ms - Total 471.369 ms / 1 intvls (Avg 471.369 ms)
