Re: Progdvb server and client problem
#91
Hi prog
I found that client module doesn't add channels to channels list, but he rename other channels from the same frequency!!!!
for example:
if i open channel mbc2 for first time after scanning for channels it will work
but later if i try open mbc2 it will lead to zee aflam (channel in same frequency of mbc2)
the zee aflam will be renamed to mbc2, and every time try access mbc2, another channel in same frequency will be renamed to mbc2!!, and so on
after all, i will have many channels named by mbc2 and lead to other channels! (usually lead to zee aflam!)
any way, i used iptv client instead of progdvb client module and enterd url link 192.168.1.1:10999/list.m3u8 to iptv client and xmltv link http://192.168.1.1:10999/guide.xml and scan iptv client.
channel list created and no problem found, plus no problem in epg events.
actually i guess iptv client is awesome since it do the same job like progdvb module plus it have no problem compared to progdvb client that actually i don't know the difference between them!.
so i will use iptv client now and i hope you can fix progdvb client module soon
thanks for your time
#93
Thu Jan 25, 2018 5:33 am
btw, server have self base of channel. And need push on ok/apply on server for apply new channels after scan.
Thanks, I noticed that !
I hope that you find solution for wrong epg and channel list problem in progdvb client side.
i use Iptv client and he have also epg problem like progdvb client plus I miss the option of channel list group by satellite - provider-network....(it useful to filter long channel list!)
Thanks
#95
Yes i can but that work only in progdvb client, if i used iptv client
it will not work!
in iptv client i can make guide time offset to correct
epg time problem , is there any way to apply time offset to all
channels instead of doing it for every channel?!
Are you plane to solve server channel list problem and EPG problem at client side in future, or those problems happens with me only?
Thanks
#101
Wed Apr 18, 2018 9:52 am
epg and from Prog Media server also?
yes, using prog media server home
if i put user and pass in IPTV client
*i can watch channels in iptv client (old channel list)
and it will not ask for user and pass
*i cant update channel list neither EPG in IPTv client
even i can access channel list through web using username and password
#103
same error message..
if i entered the link like that
http//ip:port/list.m3u8
http//ip:port/guide.xml
it will give error message 401 unauthorised even i set user and pass
http//user:pass@ip:port/list.m3u8
http//user:pass@ip:port/guide.xml
it will work...
// The prerelease solved another issue i didn't notice before
which is showing (user:pass@) before channel link in osd window
(that appear by I button)
and that's where i got the idea to put (user:pass@) befor the channel list and EPG address
