does prog media server not support XP any more?
if it support xp , did you test it with win xp and no problem found?
thanks for your time
Re: Progdvb server and client problem
#77Still not tested in XP. I plain prepare XP in virtual PC in near days.
#79make new problem with evr render and codec ffdshow
once i open any channel it work perfect but progdvb have no response to mouse action!
and it freeze and i have to restart pc
once i changed video render to vmr7(require win xp) and video codec to dscaler mpeg, progdvb work ok
but still have the same error with server module
#82The error message disappear and i can now access server module.
I can download channel list without problem at client PC, but once i click any channel progdvb at server PC crash immediately
i installed 7.22.4c also at client PC and test it but it's the same problem progdvb at server PC crash once i click any channel at client PC
logs files
http://www.mediafire.com/file/ms44l6eysmal64l/Logs.rar
thanks
logs files
thanks
#83Crash in unmanaged partGROW wrote: ↑Tue Jan 09, 2018 1:47 pmThe error message disappear and i can now access server module.
logs files
thanks
Module: C:\prog test\7.22.4.c std\ProgDVB\Modules\ProgMediaServer.Module
Thread: 0xd0c
#86thanks for the new version, no crash happened now
but there is a few issue
1. the traffic and resources graph not found as you can see in this picture
2.The epg event in client pc not the same like server pc!!
that's screen shoot of server pc where is the event is crrods
that's screen shoot of client pc for same channel where is the event is spongebob!!
3. once i switch to certain channel name in channel list the video will be for different channel!!! and that's happen for a few channel only!
4. if i switched to certain channel name in channel list and progdvb really switched to that channel, some times the channel name in top and bottom bar of progdvb will be different than current channel name!!
that's all
that's all
#88thanks for the great work
this issue still be there
1. events in client have different time than server
if there is event in server pc for certain channel timed to 13.00 it will be in client pc timed to 15.00, and client and server have same clock, date and time zone, so if it is not server problem i guess it will be client problem, if it's not client problem, could you tell me how to solve that?
2. channel list in client pc still have some problems and i noticed that the first channel list sent by server is perfect and it seems that the problem in client module in progdvb
for example if i scanned client for channels and switched to channel mbc2 it work perfect, but once i switch to other channel and return to channel mbc2 the video will be to diff channel !! and i can notice anew channel named mbc2 added to channel lit!! and every time i try to access that channel anew channel named mbc2 added to channel list and all channel named mbc2 have video of diff channel, i unchecked the option found in options-scans-update channel parameter during watch but doesn't solve the problem
if i re scan client for channels , channel list will be created and the same problem happen as descried above and that happen for a few channels randomly
any suggestions?
any suggestions?
#89Try remove all channels on server size (channel list->clear), rescan and import on client
#90in server pc i made channel list named "progdvb client" and copied fav channels to it and opened any channel in that new list and restart progdvb to make sure that list is applied to server
in client pc i go to channels-remove channels from base , and that delete all channels , then i made new scan and channel list successfully created
if i open any channel for first time in client pc, channel work perfect but i notic that client add new channel to channel list named by current channel name and probertie- url of that channel is lead to another channel!!
in other word client keep add channels to channel list and also keep changing channel-probertie-url to lead to different channel every time i accecss any channel in random way
if go to through web to server ip address ,server channel list appear and any channel can be opened without problem by VLC player and that prove that client module randomly change channel list and channel url!
update
i guess that's the easy way to solve the problem
you make a change to client module so he doesn't have permission to change channel list or channels property - URL for the received channel list form server, it's like make the received channel list is read only!! , and if any one want to delete or rename channels he have to make new channel list and copy channels to it !!
