Bug in Parent Control - Video is viewable with ESC/Options..
Hello,
I found a bug in Parent Control.
If Parent Control active...
  • ... the user can it cancel with ESC and the user can see a dimmed running video
    ... if the user go to options and closed this, the video is not dimmed, the running video is normal
    ... the user can take a snapshot from video
Pictures
Required password
After pressed ESC key
After click on Options menu with canceling
Regards/Gruß
Padman
